Toytec Ultimate LIft question
kmiller93
I have the ultimate lift on my truck with 600lb coils and no additional weight.
How much thread should be (or how much do you have) under the coil over plates to make 3in?
Im trying to decide if I should lower mine some. I think the front is sitting a bit higher then the back.
The amount of thread showing is going to be different for every vehicle. With no body lift you should be at 23" from the center of the hub to the fender. If you're higher than 23.5" I would lower it down some.
Im going to lower mine down to 23 its at 24 i think. The front looks taller then the back now plus is i put weight in the back im sure it would look some what odd.
