Tpms code adjust
piklhead
I have an 08 4runner, running 285/65R-17LT tires. To keep the TPMS light off during the winter, I have to run 30psi to keep the light off. That makes the ride very rough, not to mention wearing out the center of the tread prematurely. I Used the chalk line across the tread, and lowering the pressure untill the chalk line has worn evenly procedure. This resulted in 26psi for the front and 24psi rear. With those pressures, the light stays on all the time. 28psi is the low pressure warning setting.
Does anyone know of a way to reset the low pressure warning pressure setting? I understand the danger of this if I were running stock tires.
Any help would be appreciated.
delislerebecca
