TPMS on 2007, DIY thread?
cognus
Guys I’ve been digging through threads here on TPMS issues and have read that the system wiring and components changed in model year 2007 but cannot find details. Can someone point me to THE thread for that generation TPMS.
I have blinking indicator and need to remedy.
Thx
the brain is under the glove box, you can do the bypass and disable the whole thing. but be warned, got to check all tire pressure including spare.
Yes I had read these general remarks but had not seen wiring & DIY info for bypassing or disabling in years from 2007 forward. If someone could help.
I have blinky, not steady light, and may not keep running original Orem wheels
When you ID the colors, unplug the connector from the TPS brain box and jumper the two pins with a piece of solid wire. Don't have to re-plug into the brain box of course. I got a roll of it from the dollar store, probably for arts/crafts or fake flower arrangements. Still have 49 and 3/4 feet left.
My system was still working, just did the mod since failure is way overdue and I had other things going on under the glove box to deal with the other day.
The black/white ground wire was 3rd from the edge of the connector on row #1, pink/black goes to 3rd from the edge diagonal from the blk/wht on row #1.
the blinky means one of the sensors has a dead battery or is broken.
the fix is the same as the thread says for the 05-06 but the colors changed in the newer years but i only saw a comment about an 08 so im not sure where you are with the 07.
see if the colors match the 05-06 colors or the 08 colors and jumper those accordingly
its super easy and takes 2 seconds to do once you get the relay out.
use the red mash connector so it makes good contact
there is one screw under the dash and the panel lowers and pulls right out towards you to get it out
http://www.toyota-4runner.org/4th-g...p-how-disable-bypass-tpms-18.html#post2842355
REE
