Jixxer6
I did this for a friend with an 03 V8. He showed me a link to the mod here and it was a bright idea but I wanted a cleaner look. 1st no running wires through the firewall, 2nd use the factory switch in the stock location. What makes this a little tricky is that the stock switch is only a momentary contact switch not an on/off switch like in the regular mod. What I decided to do was use a 2 position relay. When the relay is off the ground for the brake pressure switch flows un interrupted. When the button is pressed the relay opens and causes an open circuit briefly. The skid control module will recognize the problem and turn VSC off. When you turn off and restart the car the system resets and it's back to normal again. I used the factory harness plug for the VSC switch, It's there taped up and unused. It already has the ground in it and the wires for the bulb for the switch. All you need to do is cut the red wire and attach it to the ground side of the relay with another length of wire. The relay will require a key on power. I used the black wire on the plug pictured. It was unused behind the kick panel (where I'm hiding the relay). Now all that's left to do is cut the black wire on the connector closest to the firewall on the skid control module (pictured). Your going to connect those to the relay harness. On the relay harness you need to use the middle wire and one outside wire labeled 30 on the relay itself. I made a crude wiring diagram. Keep in mind ABS module is not correct its actually a skid control module. I'll try and make a better one.
