Traction light only and beeping, HELP
hinmo24t
Hey, unfortunately i just drove my 4runner home for lunch and noticed a beeping sound and only the traction control light on. it beeped like 3 times and stopped with the light on, for about 5 sequences. the second half of my ride home (10 mins) it went away. Any idea of whats going on? I got scared seeing all these threads (albeit thankfully with more lights on than me,) either cleared by battery reset or the main pump or system controlling VSC/traction/abs is failing and can be multiple thousands to replace??
Thanks in advance.
sounds like dieing battery or bad connections.. usually when it does freaky electrical stuff thats what it is.. if it was happening under specific conditions or more consistent circumstances then it might be a mechanical issue
thats reassuring, ill check out the battery. thank you...
charlesz
