Trail Mirror Upgrade
Senior Member
How difficult would it be to put Limited's Mirrors on Trail rig? I like built in lights in those. Is there a harness in the door for blinker and puddle bulbs or Toyota cut that before doors in Trail? Also, can mirrors be bought color keyd? Thanks for input
how difficult would it be to put limited's mirrors on trail rig? I like built in lights in those. Is there a harness in the door for blinker and puddle bulbs or toyota cut that before doors in trail? Also, can mirrors be bought color keyd? Thanks for input
x3...........
What do you like more about the Limited mirrors? Are they the same as the SR5? I kind of like the no nonsense trail mirrors better than my SR5.
if you have a magnetic grey sr5, I will trade mirrors with you. sr5 and limited are the same. PM me.
Did anyone ever figure this out? Seems like they would have the wiring there already, since the trails are much more rare than the sr5 and limited models.
Shouldn't be too difficult seeing as somebody has already fitted the new 4runner mirrors to a Tacoma without having to splice any wires.
Sshhhh....Very possible and fully functional....
wow i would love to do this...
any folks in the norcal area good with tools and wanna trade? looking for that utilitarian mirror look? :nerd:
The covers can be bought colour keyed from Toyota for $36.53 each from http://www.trdparts4u.com.
I added the mirrors a while back and dont recall exactly what was done and no pictures were taken, but Ill try by best. I cant believe these mirrors didnt come factory with the vehicle. This mirrors that I purchased were aftermarket; KOOL mirrors replacement.
There were basically four wiring obstacles. Changing the mirrors with the stocks were straight forward, swaped. You can access the internals by removing the mirror from the body. Wires are; turn signals, flood light, mirror controls, heater (I did not power this- I live in an area that doesnt freeze), and ground. Most of the wires were splice into the factor harness (harness that was used to plug into the factory mirrors).
For the mirror controls, I believe there were two wires which control up/dwn and lft/rgt. I just had to play with these wires with the factor harness to get this right.
For the flood light- first I swapped out the bulb to a led which is really nice at night. You can either use the door lights which can be spliced in right from the door- downside is when you use your remote to unlock the doors, the flood lights will not light up, only when you open the door will it light up. Or, you can wire it to the dome lights which do light up when the doors are unlocked with the remote.
Finally the turn signals. I tired to find the turn signals through the access panel but couldnt find it, so ended up running a wire to the front turn signals.
All in all a very simple and easy install...hope this helps.
Crazy that the wire harness is totally different between models. Was thinking of doing this mod but now having second thoughts.:mad:
Toyota sold 8,557,000 vehicles last year alone and I guess they figure an unused 5ft of wire and and a 10 ft of wire there and a extra connector here and there can add up to some real change. Dang bean counters!
You could still do it for looks as you don't have a working turn signal or puddle light there now. It's basic wiring 101 to tap into the turn signals and over head lights and shouldn't be that hard.
