What year was the last year that they made all black roof racks for the trail edition....and will they fit a 2015 model?
Absolutely. Many have done it on here!It's funny how Toyota does that with the roof rails. I bought a 2004 SR5 and it was all Silver but Black Roof rails. The 2004 Limited Edition however had Silver Roof Rails.
Now the 2015 Black TRD Pro that I currently have is all Black but has silver roof rails. At the car wash and the window tint place they both said the same thing...get black plastidip and then apply the clear gloss plastidip. For less than $10.00 I got both and will put three coats of each on the silver rails. On a garage kept vehicle it should last about 5 years supposedly.
Could be an option worth a look?
You have them in the wrong position. I have a 13 Te rack on my 15 w/crossbars no issuesGuys so I added the rails from a 2010 TE to my 2015 SR5 that I got from a guy off Craigslist. The rails are all good. Not figment issues. The problem I've got is that the crossbars are about a 1/4 too long to fit.
Has anyone used both the rails and crossbars on a 2014/15 and if so did you need to trim them to fit?
One crossbar is wider/longer that the other. Ever seen this?
Supposed to be that way
narrow out back. leave the rails loose, slice in the cross bars and then tighten it all down makes it easier ***EDIT *** I see you figured it outShort in the front I'll assume?
And they should be able to slide in after the rails are mounted correct?
