Trailer hitch bolt-up
mreloc
I'm mounting a class III Reese hitch that came without hardware. How much trouble am I begging if I rely on the 4 towing hook bolts only as hardware to mount the hitch? Only plan to do light occasional landscape towing/bike rack type stuff. If I really need to do the two other bolts at the front how in the heck do I get the bolts in and through the frame? Any tips to share?
What year is your 4Runner?
On mine, there are welded nuts inside the frame rails. For the rear most cross member, Hidden Hitch includes nuts that are mounted on a metal tab, almost like a spoon, so that you slide and position the nut through the access hole in the rear cross member.
stc6306
