trailer hitch
JP4RNR
Since I don't tow how much weight would be removed by taking off the trailer hitch. I have the hitch that goes with the V8 it's a 2006 4Runner
ETrailer shows the shipping weight as 33lbs. I'd say you're within a pound or two of that. Not worth taking off IMHO (like that V8 will notice 33lbs :lmao: ). Put a step in it, it'll make washing the roof easier:D
I have a v6 and keep the hitch in from may thru october. and yes it does work well as a step to wash the roof.
I was actually thinking more than just the hitch but the hardware the hitch connects to bolted to the frame of the truck.. I have the weight distributing hitch and it is attached with what looks like 20mm bolts. I figured (6) 20mm bolts must be holding something heavier than 33lbs
Well yeah man.. its also gotta lug around thousands of pounds...
No, the 33lb number is for the receiver assembly. I used the wrong terminology:bash: It's 33lbs for the box, bolts and the whole, big mechanism that bolts on the underside of the truck. When I did mine it was easily manageable and I don't doubt 30lbs +/- for a second.
:cheers:
thanks for the link
thanks Koz I was unaware of such a product.
The hitch and the undercarriage mounting assembly (to my mind) are good protection for the rare occasion off roading. Prevents expensive damage to the bumper and floor pan back there.
Just my 2 cents.
Just my 2 cents.
I had a $250 hitch step and my wife backed into a tree (Yes, even with a back-up camera). The step hitch prevented any damage to the vehicle but bent the hitch and had to be replaced. This caused me to look for something a little stronger and I found the Superbumper. It WILL withstand a good impact without any damage and is worth every penny, with its lifetime replacement guaranty. The con is it is chrome plated/powder coated steel and will rust, but it is still worth it. You just need to give it a little more attention.
So Superbumper, if you are out there, you need to make it out of stainless steel!
Koz
Laredotx
