tranny issues need help guys
mudbogmafia595
What's going on all new to the site so i figure ill just jump onn in I've owned a 92 t4r 3l with the auto tranny i recently took it for a spin its mostly a mud truck so it doesn't get much pavement time i noticed it was shifting kinda funky and on an incline or cruising its making a noise that mocks rod knock but from the tranny oddly enough it shifts fine its just the power loss if i stomp on it it will downshift good and no noise and at idle and 1st not a sound? The tranny code says the #1 solinoid is shot but what the heck that noise sounds bad and I'm prety shure the bad sol wouldnt make a rapping noise. I'm not to. thrilled with the thought the trannys shot so any imput is appreciated. thanks
New trans fluid is bright cherry red, worn is a real dark red, brown is not so good. Did it smell burned?
If your getting a bad #1 solenoid code, then replacing it is a good place to start.
No, the fluid was burnt beyond color its the 1st time its been changed by me and who knows last time the orig owner did it.... i mean if its the #1 sol no issue ill change it out but that rap doesnt sound like a sol-valve body or low/high fluid scenerio im just currious what the heck coulda maybe broke and lead to this...? im just not playing nancy drew with the tranny if its a major thing ill just buy a used one but if its a common or similar issue whel...
