Trans "slipping" from 2-3
zoombyu86
It didn't start until I had solenoids go bad and replaced them almost a year ago.
-It does not throw a code
-shifting from 2->3, it basically goes into neutral. I have to put it into "N" and back into "D" and then it will shift fine through the rest.
I'm sure It happened when I dropped the pan to change the solenoids and somethings "knocked loose." Do I have any options other than dropping the screen and draining, hoping that whatever is loose will come out? Not sure if it's stuck in the valve body, I dont know how these things work.
seltzernator
