downshift
I was in a tight parking lot covered with packed snow and ice, or really snow that had partially melted during the day and froze at night. I was in 4Hi, which locks the transfer 50/50 front/rear. I had to use full steering lock to squeeze into a tight space. The outside front tire, unable to rotate, lost traction. I started understeering into the parked car on that side. Luckily, VSC kicked in, braked the inside rear wheel, and saved me. I also hit the brakes, a fraction of a second after VSC kicked in. I stopped just inches from the other car.
Speed wasn’t a factor, I was just creeping along trying to squeeze into a tight parking space. Brake induced lockup wasn’t an issue either, I wasn’t on the brakes until after the tire locked up.
Is there anything I could have done differently in this situation? Gone back to 2WD? Made a multi-point turn (a 3 point turn would still require full lock, I would have needed a 7 or 9 point turn)? Used 4Lo, crawl control and A-Trac?
How often does transfer case induced bind cause issues like this? Searches only return bind issues on dry pavement, that’s not the case here. I’ve never seen a post about anyone saying “bind induced understeer caused me to run off the road into a ditch.” I’m a bit worried about this, am I worrying needlessly?
