Transfer case bind almost caused an accident
downshift
I was in a tight parking lot covered with packed snow and ice, or really snow that had partially melted during the day and froze at night. I was in 4Hi, which locks the transfer 50/50 front/rear. I had to use full steering lock to squeeze into a tight space. The outside front tire, unable to rotate, lost traction. I started understeering into the parked car on that side. Luckily, VSC kicked in, braked the inside rear wheel, and saved me. I also hit the brakes, a fraction of a second after VSC kicked in. I stopped just inches from the other car.
Speed wasn’t a factor, I was just creeping along trying to squeeze into a tight parking space. Brake induced lockup wasn’t an issue either, I wasn’t on the brakes until after the tire locked up.
Is there anything I could have done differently in this situation? Gone back to 2WD? Made a multi-point turn (a 3 point turn would still require full lock, I would have needed a 7 or 9 point turn)? Used 4Lo, crawl control and A-Trac?
How often does transfer case induced bind cause issues like this? Searches only return bind issues on dry pavement, that’s not the case here. I’ve never seen a post about anyone saying “bind induced understeer caused me to run off the road into a ditch.” I’m a bit worried about this, am I worrying needlessly?
it had enough traction to bind up and cause understeer and increase your turning radius. just drive slow and do a multi-point turn or change into 2wd
Sounds to me like you were just going too fast and hit a slick spot. If you're going fast enough for VSC to kick in then hit the brakes then you're not "crawling" in my book.
I am trying to figure out where it is still snowing this time of year. It has been in the 100's here. Sounds like you need a Limited with full time 4x4.
I assure you I wasn't going more than 1 or 2 MPH. I mean, how fast can you go when you are pulling into a tight parking spot at full steering lock with cars on either side?
I did a Google search for any reference to a minimum speed for VSC to kick in. I didn't find anything official from Toyota, just opinions. They range from no minimum to 5 to 10 or even 15MPH. There is no way I was going 5MPH, let alone 10 or 15.
How often do you find yourself on an unintended path due to transfer case induced bind?
Go to 2wd. It's the only way to make full lock turns and not push the front wheels some. The other option is point turns.
One thing I learned during my years of off-roading is that no matter how slick you think it is, prepare for a little binding type action if making a sharp turn with the 4x4 engaged.
Best bet is to do a multi point turn.
Yup, multi-point turns.
But my question is, where the heck are you right now!? I'm in Oregon sitting on my patio reading this at 10:39pm in shorts and a Hawaiian shirt.....
Sounds like multi-point turns are the solution, or maybe 2wd, depending on the situation. Sometimes 2wd wouldn't be wise... :)
This was last winter. I had kinda forgotten about this incident until recently, when it just popped back in my head for some reason. Perhaps something I read here triggered the memory.
044runner4
