atalarico
Senior Member
**So, I wound up finding some good write ups on this job between the time I wrote this and now. Depending on my mechanic's estimate, I might try it myself.**
Like a good boy, I decided it had been too many oil changes since the last time I greased the ol' drive shaft zerks. I loaded up my grease gun, and went to work. It seemed to take a lot of grease this time around, so I figured I have been low.
I've been smelling a little grease burning off after driving for a while, but just figured that was normal. I came out to the parking spot this morning and saw a nice little 5"x5" puddle below where the front drive shaft connects to the transfer case. It appears the seals have gone bad.
What I'm wondering is the following:
1.) How urgent is this fix?
2.) Can a guy, with limited tools and only a carport, undertake this job in an afternoon? I don't have a torque wrench, or an impact wrench. It's probably time I just go buy a torque wrench at least anyway, but is it really possible to pull the 30mm nut off without an impact wrench? How much would an adequate torque wrench set me back?
3.) What's a reasonable cost for a mechanic to charge for this job? The parts are less than $20, but just wondering about the time. I'll bet if I had a lift, an entire garage, and the experience of doing it before it wouldn't take me more than an hour or so.
Thanks!
Thanks!
