Transfercase Brake for V6 3rd gen?
bikerjosh
Does anyone know if a transfercase brake is made for use with a 3.4 v6 on a 3rd gen. Sky Manf makes one for the 2.7 4cyl motor, but nothing is listed for the 3.4. BTW- I'm looking for a tranfercase brake kit, because I have the rear disk conversion w/ebrake tabs. I was going to buy new calipers, but the brake cable take up, appears to be a bummer to solve. 4runner stock ebrake system does not pull much cable. With a disk set up, you need to pull much more cable length and pull evenly on both sides
Thanks Josh
:hiding:
Goooooooogle it!! :)
Wow, what a concept. Google huh?
Ummmm, already checked there and found lots of threads but only in regards to 4cyl or gear driven transfer cases rather than 3.4 V6, and chain driven transfer cases.
Do you know of a specific company or were you just directing me to look elsewhere?
Thanks for the advice. Yep, I looked on there and got some ideas, that may work. I'm still trying to decide if going with a transfer case brake, or swap out calipers for Eldorado e-brake calipers and fabricate a new cable system that will increase cable take up rates and angles.
thanks Josh
johnnya
