Transmission cooler install question.
jsmith811
I just installed a B&M Cooler in a 1998 4runner, about to install a 2nd cooler on my 01 limited 4runner, any issue just using two of these to connect to factory hoses.
It's not a big deal to replace factory lines, but I didn't like the amount of force I had to use on the rigid transmission lines that the new hose attaches to, I was waiting for them to bend or give when I was pushing those new lines on during last install.
I replaced the lines. Used a little trans fluid on the metal lines coming off the trans and the new lines slid right on no problem.
Did you use the hoses that came with the cooler? If so, you should have gone to the parts store and bought about 5' of 3/8" ID cooler line hose. These slip over the hard lines easier.
