Transmission Cooler?
MicD
I am looking for a good transmission cooler for my '08 T4R v6 4x4. I tow quite a bit with it. Can anyone recommend a cooler that would work well and be fairly easy to install?
Hard to say what’s “good” as there are lots out there. A lot of folks install a Hayden cooler. Others install the B&M or Tru-Cool. I myself went with the Tru-Cool 4544 as it uses LPD technology to help the oil heat up faster when cold and they also had the oil cooler I wanted. B&M also has LPD however I don’t believe Hayden has this feature. Overall I don’t think you can go wrong with any one of these coolers as they are all of good quality.
Make sure to get one with a 3/8” barb as the tranny lines on your runner are 3/8” O.D. Also you may need to buy about 6 feet or so of 3/8” I.D tranny hose to do the hook up. Most kits come with 4 feet of hose and for some reason use a slightly smaller hose, like 5/16 or 11/32 or something like this, and it can be hard to get the hose to fit the lines coming off your transmission. Obviously some of this depends on where you place your cooler and where you tap in.
