Transmission issues
541joseph
Don't have time to search but when in any gear it feels as if there's a miss. And when shifting the it again feels like a miss. Anyone have this issue? I'm about to have a uses trani shipped but don't really have the money so please help
You can have a slight miss and not throw a CEL. How long since your serviced the trans, or is it a manual? Engine tune up?
It's not a slight miss. And the and trans service was less than 5k ago. Turns out it's a miss on all 6 cly at 2500rpm under load. Changing spark plugs hoping that it fixes it.
How did you find out all 6 were missing? Was there a stored code? If it's missing it has nothing to do with the trans. I'd replace the wires also.
I know the trans has nothing to do with it. It just feels as tho it does. And money is very tight so I'm going to do plugs and then if it doesn't improve as dramatically as it should it will be wires then coil packs.
And we found out by putting a timing light on the wires and made it miss and you can watch it not fire and because both cyl fire you can tell it's all 6
