Transmission shifting at high rpm ?? Why ??
SeashaAnn
I have a 94 4Runner four wheel drive V6 and my transmission won't shift until I get to about 4000 RPMs in each gear, and to get into overdrive I have to do almost 70mph. it's causing me to run at high RPM's and it's eating up my gas. My check engine light is not on so I can't get a code to find out what it is.
I like to mention I'm a girl but I'm not a dumb girl so I've been trying to investigate what it is and I've come across a few different things.
Possibly a speed sensor, a shift solenoid , throttle position cable, or TpS sensor...
I'd like to try to pinpoint what it is instead of having to replace all these parts because it's quite costly.
Any help on the subject would be greatly appreciated and if you need any more information on the subject let me know please and thank you.
I have a similar issue and am going to replace the 3 solenoids when it warms up.
I got all 3 for $60 off ebay
Did you replace the solenoids? Did it fix the problem? I don't have the money to buy and replace something that isn't gonna fix my issue, and getting someone to do the work is not easy either ( I am a girl and even changing the spark plugs on my motor is a pain in the ass)
So I was hoping to hear if it worked for you...
And FYI, I asked my truck and told her if she tells me what s wrong I'll fix her, but the check engine light is not even on...
Sent from my SM-G900R4 using Tapatalk
Here's the diag section from the service manual for the A340H automatic transmission, which is what should be in your truck. The transmission has its own diagnostic system, and won't light the CEL just because something is wrong. The transmission diag system uses the OD light to blink out the codes.
Hope this helps. Good luck!
(BTW, SST 09843-18020 is just a jumper wire. A paper clip works just as well.)
BTW, don't apologize for being a girl. Changing the spark plugs on a 3.0 V6 is a pain in ass no matter who you are. Takes at least two more joints in the forearm and wrist than most people have.
Keep asking questions and you'll be able to get to the bottom of this.
I can't open up that file do you think you could possibly email it to me to at [email protected]? ?
I'm on a 5 speed with my 2nd gen so I might not be the best help but my auto has an ect button that causes shift points to be higher for added torque during towing. I've heard it can malfunction and cause shifting issues. The solenoids are gonna be your best bet though. That's the usual suspect with the auto trannys
No, 1st, it doesn't shift the same as when I had used it before this problem.. and also I have tried to use it since and it makes it worse... I now know about the troubleshooting I can do for the tranny. Posted above , and I just haven't had the chance to do it.. hard to fit in mechanics when I'm watching grandbaby, work, and the cleaning and other womanly duties..
But it is looking like the Shift silioniod... hopefully my truck will tell me when I do the codes...
But also questioning if I can just change the shift silioniod or do I have to do all 3... and could I get away with swapping from another tranny or get them new... I know new is always better, but have very limited funds and have friend who has 3 parts trucks. And may have one that the engine went bad in the transmission still good but I'm pretty sure it's easier to change the solenoids instead of the whole tranny.
But I worry about all those issues after I troubleshoot
If the tranny was in good shape before the motor went then a replacement tranny wouldnt hurt if the miles are lower and wasnt ran like a race car. The solenoids are gonna be the easiest option though cause you just pull the oil pan and filter and replace the solenoids in the same compartment. You're gonna have to buy a new tranny filter and tranny fluid to replace it all though. If I remember right, all the solenoids are on the side of where the filter goes and arent hard to replace. It's a messy job so make sure you have your garage floor covered
Ya, I have already checked it out and have it saved to my phone the diagrams showing where they are located... did not know yet about the filter and fluid. Was gonna find the section from manual on it before getting it done...
Good idea. Ya you'll have to refill the fluid when you replace the solenoids cause you have to open the oil pan and if you're already there you might as well replace the filter so you're not putting fresh oil through a dirty filter. Preventative maintenance really
Just because it's a no brainer, did you verify you have enough transmission fluid? We had a similar situation right after we acquired a 1993 and it was easily resolved by adding the proper amount of fluid.
Good point. Don't overlook the simple things. Automatic transmissions are very sensitive to fluid levels.
Changing the solenoids is pretty easy. I did mine in an hour in a dirt driveway while it was raining. I would buy all of the solenoids. There is no sense in dropping the pan and just replacing 1.
1. Drain the transmission fluid.
2. Remove transmission pan.
3. Remove transmission filter.
4. Remove solenoids and replace with new ones. (1 bolt and 1 plug if I remember correctly)
5. Install new filter.
6. Clean old gasket off of pan and transmission.
7. Install new gasket and install pan.
8. Add transmission fluid.
This is just a quick list, but it's is not a hard job at all.
I had the tranny fluid and filter done a couple months ago when I started having problems with the shifting.
And had rechecked the level after about a week of driving after also to make sure it was still full..
I haven't had the $$ to get silioniod s yet , but I'm hoping that when do reolace them it will fix the shifting issue...
Because I love my truck an it's almost summer and I need to be able to pull my boat to the lake.
Thank you [emoji4]
1993 4Runner low rev shifting
Would a solenoid swap also fix a problem of shifting then the rpms drop off between shifts. Or is this related to a vacuum leak or torque converter?? This is on an 1993 4Runner auto trans.
Code and fuel system expert needed
I have a 1900 4runner sr5 5 speed and it has a check engine lite and it flashes 1 5 2 5 and the smog guy isn't sure if that is a 25 and 52 code or a 15 and 52 code etc.
It hesitates and surges slightly under acceleration until 4800 rpm at which time it runs properly until 5300 where i stop revving it.
it idles fine and never misses and runs smooth if you sit in it in neutral and rev it up
any way to determine exactly what codes are showing by this flashing sequence?
it has 31" tires and is pathetically sow to accelerate . is this normal?
any ideas what the prob might be?
any way to test a throttle body to determine if it is not working properly?
thanks in advance for any help?
AndiGarage
