mtbtim
Elite Member
I just found some information on a website regarding transmission temperatures and how it relates to the life of the fluid. Normal driving will raise your temperatures to around 80 degrees celsius or 176 degree fahrenheit. At this temperature, the fluid could last you up to 100,000 miles. But, most transmissions will get hotter than this for various reasons (towing, driving up a steep 4x4 trail, etc.). For every 15 degree celsius above 80, the fluid's lifespan is cut in half. At 90 degrees celsius or 194 degrees fahrenheit, the fluid will last for 50,000 miles. At 110 celsius or 230 degrees fahrenheit which is commonly encountered in many transmissions, the fluid life is cut to 37,000 miles. I guess this is why it's suggested to change your ATF at 30,000 mile intervals. At 120 degree celsius or 250 degrees fahrenheit, the life of the fluid is cut to around 9300 miles.
The hottest I've seen my trans get is 232. That was from driving up a steep mountain road, carrying a bunch of gear and pulling a motorcycle trailer. I have since installed a B&M 70264 cooler in series with the radiator cooler and have seen a 20 degrees temperature drop. So, hopefully I won't be seeing anything much more than 210 in my rig now.
So, if you're regularly seeing temps above 230, you should either be doing something to get the temps down or changing your trans fluid much more often to extend the life of your transmission.
Here's the link to the website if you'd like to read more. I think you'll find it pretty interesting.
http://www.thetransmissioncentre.com.au/general-information/
