TRD Dynamin Tensioner Removal
clt750
I need to remove the super charger dynamic tensioner to get to my thermostat housing. Can I relieve the belt tension by just moving the dynamic tensioner and slipping belt off, and then removing the one bolt that holds the dynamic tensioner on? Is it that simple?
Yes, it's that simple. You may have to also remove the dynamic tensioner bracket as well because it might make it hard to get that upper thermostat water neck housing nut off. Go to play time 1:00:56 to see how you can get the belt off and back on utilizing a 3/8" drive ratchet.
charlesz
