TRD Limited Fat Bike Hauler v1.1
I have a 2019 so I'm not sure if certain parts are slightly different. I used 2nd Chance's parts list to do my conversion as well.
If you get the TRD skid plate, you don't need the lower radiator air dam valance and OEM skid parts (52129-35030 and 51450-6005). You will need to remove your old radiator deflectors regardless and add new ones (53293-35020 and 53294-35020).
See below for the list of parts that I used. Some of the part numbers for clips are the same throughout so the names may be arbitrary. Also some of quantities for the clips (75392-35220) are wrong depending on whether or not you want valance trim from the Off-Road or Pro.
The reinforcement bar components are not included below. The limited uses a different bar so it needs to be replaced. I highly recommend you try to find a complete reinforcement bar set for sale used, it saves you a lot of time and money. There are a number of parts you need separately otherwise and they add up in cost. I picked up a complete set for ~160.
You'll also need the bumper. If you decide to get a new one, just get the OEM one and do not save money on this part.
Part NumberPart Name
90467-07201Fender Liner Clip 5
52116-35140Bumper Cover Retainer5
90467-05138Bumper Cover Retainer Clip2
90159-60215Fender Liner Screw 2
52127-35100Fog Lamp Bezel 1
52128-35080Fog Lamp Bezel 1
75392-35220Fog Lamp Bezel Retainer 20
52114-35040License Bracket 1
53112-35060Lower Grille 1
52134-35070Retaining Bracket 1
52133-35060Retaining Bracket 1
52148-35120Stopper 1
90467-07211Sight Shield Clip 5
53293-35020Deflector 1
53294-35020Deflector 1
53875-35150Fender Liner 1
53876-35150Fender Liner 1
90189-A0002Fender Liner Grommet4
PTR60-89190Toyota 4Runner TRD Front Skid 1
53101-35080-B0 (SILVER, 2019) [different than 2020]Grille Assembly 1
Thank you so much for updating this thread I really appreciate it.
So the original TRD Suspension pretty much rusted out.
I also picked up a top spacer for the rear.
I installed the new LED Lights and they are the single best modification. I also installed the driving lights.
Did you ever figure out the 4 more parts behind the grille? Also, can you confirm the need for the lower radiator close out panel if using a TRD skid plate?
I realized I posted this in another thread and should have posted this here also.
So this is what it takes parts wise to make the swap the front and rear bumpers from a Trail/TRD to a Limited. There are 4 more parts that I will add tonight when I get home. Which are behind the grille ducting air into the radiator.
I am still trying to figure out if there is a lower radiator close out panel that is used when you have the TRD Skid Plate. So far we have tried two of them and neither work.
Thank you!!
Part Number Part Name
90467-07201 Fender Liner Clip 5
52116-35140 Bumper Cover Retainer 5
90467-05138 Bumper Cover Retainer Clip 2
90159-60215 Fender Liner Screw 2
52127-35100 Fog Lamp Bezel 1
52128-35080 Fog Lamp Bezel 1
75392-35220 Fog Lamp Bezel Retainer 20
52114-35040 License Bracket 1
53112-35060 Lower Grille 1
52134-35070 Retaining Bracket 1
52133-35060 Retaining Bracket 1
52148-35120 Stopper 1
90467-07211 Sight Shield Clip 5
53293-35020 Deflector 1
53294-35020 Deflector 1
53875-35150 Fender Liner 1
53876-35150 Fender Liner 1
90189-A0002 Fender Liner Grommet 4
PTR60-89190 Toyota 4Runner TRD Front Skid 1
53101-35080-B0 (SILVER, 2019) [different than 2020] Grille Assembly 1
Just wanted to come by and say thanks for all the information in this thread. New Limited owner from Taiwan here. This thread has given me the confidence to source all the parts and do the conversion over here. Ordering all the parts now and shipping them overseas so I can do the conversion!
You're welcome and I am sorry I missed you post. How did it go and where you able to do the swap ?
What shock/spring combo did you go with?
The factory set up as I mostly use the bike for hauling my mountain bikes.
Hello. Out of curiosity did you notice any substantial difference in pavement driving after getting rid of the 20's? Softer at all?
The biggest change was getting ride of the XREAS suspension. The ride was more firm and predictable vs the soft ride of the XREAS.
Actually still waiting for the parts lol!! They just arrived and still clearing customs. Hopefully I can get it soon. I've been waiting forever.
Next step was the trail rockers and the factory nerf bars.
I purchased the Nerf Bars from a new member on the board and he shipped these to me as promised. Daniel is a great guy and I can't thank him enough.
I originally cut up the limited rockers to see if I would like them.
But I didn't so back to the dealership to order more parts. I also ordered the pieces for the roof rack while I was there.
Cut rockers coming off
I also ordered the factory mud flaps
What are the part numbers for the stuff you picked up at the dealer to delete the limited rocker pannels?
