TRD Limited Fat Bike Hauler v1.1
2nd Chance
As Purchased
Current with Updates
Stage 1 Chassis
TRD Wheels w/BFG Tires
Toytec Spacers / TRD Suspension / TRD Skid Plates
Stage 2 Paint & Body
Trail Hood Swap
Blacked out Chrome (Bumper & Trim)
Vent Visor Part # 894027
TRD Pro Rear Lift Gate Handle Panel (Black) 76811-35220 $115.16
Roof Rack Front End Caps (Black) 63491-35030 + 63492-35030 $38.55pr
Roof Rack Rear End Caps (Black) 63493-35030 + 63494-35030 $38.55pr
Stage 3 Rocky Road Roof Rack & Running Boards
Rocky Road Roof Rack modified for Fat Bikes hauling
Planning the Rack Build - Concept
Fabrication of the rack
Wheel Trays & heading to Pro-Tek Powder Coating
Roof Protection & Removal of OEM Cross Bars & Installation of Roof Rack
Finished Rack
Bikes on the Roof
Trail Rockers & Nerf Bars
Toyota Mud Flaps
Stage 4 Interior Protection
Weather Tech Floor Matts
Canvas Back Rear Cargo Matts
Chris Kyle Seat Covers
Stage 5 Lighting
20'' Rigid Behind the Grill Light Install
Morimoto Headlights & Driving Lights Installed 02-29-20
LED Tailgate Light ( Chi-Town 4X4)
LED Hood Light
LED Interior Lights
Stage 6 Trail/TRD Front & Rear Cover Swap
Research & Parts List Post #112
Excel Spreadsheet Post #148
Collecting all of the Parts
Front Facia & Rear Facia Swap
Front Cover missing pieces
Rear Cover missing pieces
Stage 7 Carbon Fat Bike Dream Build
Trek Farley 9.6 Build
Farley 9.6 is getting closer
So I bought another "Farley" a "5" this time which is Aluminum
Stage 8 TRD Suspension
TRD Suspension Chi-Town 4x4
Cleaning up the TRD Suspension
Packing it up to Drop off at Village Auto
Install Pics from Billy
Limited Side by Side Look
Finally parked next to a stock Limited
BFG 275 Tire Swap FINALLY !!!
Time to Visit Discount Tire
Other Projects
70 Camaro 2nd Chance
92 Sonoma GT Syborg TT
More to come...
Now it's time to find a roof rack that works with my goals. After looking at all the rack option I choose to use the roof rack from Rock Road Outfitters.
Using this rack would reduced the amount of fabrication needed for my end goal.
They fit however the rear tire was too far back which would limit the rear hatch from opening when the bikes were on the roof.
Plan B
Move the Fork mount 10" forward and remove the sleeves from the Kuit trays and recreate the concept with PVC tubing.
Next Step was to come up with a rear wheel tray that accommodates any tire combination.
Since I haven't welded in 30 years I headed to High Speed Welding in Westmont, il and asked him to fabricate the fork brackets and rear wheel tray.
Using the Kuit fork inserts allows me to quickly change fork combinations.
I plan to use a 3/8" ARP 12 point hardware to retain the fork inserts.
I needed a wheel tray that could accommodate a 5" tire. This is what I I can up with.
I asked Dennis at High Speed Welding to cuts slots in the trays so I could use a Saris Fat Bike Wheel Strap.
Also, This is what the finished rack looked like the day I dropped it off at Pro-Tek Powder Coating.
The next step is to De-Chroming the truck. At some point I may swap front ends to the trail version but for now a wrap will hold me over.
Quick trip to the guys at XTreme Graphics in Lombard, Il for a Satin Wrap.
I want to thank the other limited guys on the board for posting there pics as it made my decision. I choose to wrap vs powder coating.
Since the roof rack hides most of the roof I wanted to protect the paint from crud that falls off the bike.I also want to protect the roof from the accidental fork jab that sometimes happens when you carry it up to the roof. So I asked the guys and gals at X-Treme to wrap the roof in black vinyl which should offer plenty
Quick picture of the rack fresh from the Powder Coater and ready to install.
Step 1
Remove the plastic end caps from the stock rails so you I can install the modified Rocky Road roof rack.
I took these picture so people can see how easy it is to remove the caps. Just slide the tool under and pull back gentle.
Step 2
Loosen the hardware on the drivers side so there is room to tip the rack up. On the Passenger side remove the hardware completely.
Step 3 -- find a friend
Since I was flying solo and the instructions said that a friend or two would be helpful I decided to call my dog I know he's not much help when it comes to lifting but oddly enough he's good company. Plus all of my friends were out riding without me.
Step 4 -- Read the Instructions bla bla bla
Since I'm doing this myself and after reading the instructions I realized that it would not be possible to follow them. Main reason was the Satellite antenna would be in the way and they wanted you to slide the rack in from the rear of the truck. I decided to step back and look for a better way that one person could install the rack. I decided installing the rack from the Passenger side of the truck would be much easier for a solo job.
Personally I like picture instructions better as I am a visual person plus lets be honest most of us don't actually read the instructions.
Sorry no picture of me reading the instructions.
Step 5 -- Run a tap through all bolt holes
To be safe you should run a tap through all the threaded holes just to make sure there was no powder on them.
Assemble the side brackets and slide them into the drivers side factory side bars.
Prop up the passenger side of the rack with a 2 x 4 Remember the drivers side needs to be loose so this can happen.
Remove the Passenger side bar and slide all 3 brackets into the factory rack rail (Found the Picture)
Using a ladder install the factory side rail with the Rocky Road brackets onto the Rocky Road Rack and then secure the factory rail back down.
Make sure you center the Rack and then tighten the factory rail bolts down and finally tighten the bolts on the bottom of the Rocky Road brackets.
I am very happy with the Quality of the Rocky Road Rack and for the money you can't find a better rack.
Rear wheel tray
Added 1/4" nylon spacers under the tray to elevate the tray up enough to clear the Rocky Rock Brackets.
I am very happy with the finished concepts. Yet to install are the Saris extra long strap.
with the Saris Straps installed
Close up of the fork brackets.
And finally pics of the bikes on the roof.
Still waiting for the Stealth Maxels so I can make it a little harder for would-be Thief's
Happy Farley Family!
Where in the world do you ride fat bikes in Chicago? Kettle Moraine? If you come up to MN for the Fat Bike Series, give me a shout!
A ton of attention to detail on this rack...very impressive. I never imagined trying to fab a fork mount to the roof. Nice! I'm just hanging my steeds off the back with my Kuat...which I'll plasti-dip at some point this month.
Nice rides!
Nice rides!
We have about 40 miles of trails located in Palos, IL and the bike loves them. We go from supper rocky technical trails to dirt roadie trails. Something about this bike makes me want to just ride it.
My buddy and I have talked about riding Blue Mounds State Park and even Copper Harbor and now I have to convince him that we need to head your way for the Fat Bike Series.
and Yep we ride Kettle and Brown County
The black bike has the 27.5 plus WTB Scrapper rims with 3.5 Panaracers Fat B Nimbles on it and it rides just like my old cross country bike.
Awesome job! We have some fat bike beach cruisers and are looking to get some fat mountain bikes now that we moved here to Utah. One of the biggest issues we've had is transporting them!
Good decision to go with the wrap. Had mine wrapped in brushed black aluminum and the emblems plastidipped. The plastidip on the limited emblems on the side of the truck are coming off already.
Also diggin the redwood interior... Nice choice.
Nice. I've bought and sold 7 fatbikes over the years. The carbon Beargrease FINALLY made for a good handling bike, yet I didn't want a $6000 bike that gets ridden a few times a year. Most fatbikes handle like pigs. Then.....my buddy was selling his pimped out Farley and it rode like the Beargrease at a fraction of the cost, so I swooped it up and pocketed the leftover. VERY nice bike...esp for the price!
Your truck was one of the reason's I had had my chrome wrapped and eventually I plan to actually powder the bumpers satin black for a more permanent solutions. But this works for now and it cost a whole lot less.
btw I am doing the trail hood just like your truck.
My favorite thing about the Farley is it handles like my old hard tail and with the 27.5+ wheels it's even better.
Hey someone from the Chicago area. Maybe I'll see you on the road somewhere. I'm in Glenview
I try to hit a couple cruise nights in the summer when the weather is decent. If the weather is good this weekend I might be in Lombard with this car or the truck.
Best $159.00 I have ever spent.
I also added some rubber tread to the roof rack.
I had planned to use the anti-slip stuff from a skate board. But found this at Home Depot last night and it was the exact width and the length was close enough.
I forgot to mention the guys at Canvas Back even included two dog treats. Which my dog enjoyed.
