TRD PRO FOX Shocks perch question.
Silversurfercal
Hi all, quick question, can you adjust the perch settings on the FOX Trd PRO coilovers ? i know you can move them one spot up on the billstein TRD shocks , can you do the same on the Fox? Planing on putting them into a KDSS 4Runner and want them to be the same height to avoid any lean, thank you.
After looking at mine...NO!
Look at the Cornfed et al spacer on one side to level it out .25 or .50 to level it out.
I was almost thinking 3/4 or 1" since the lean is almost 1.5 right now . i was thinking of putting them in the front, since that's where the "deficit" comes from.Thanks for checking, i was hoping you could just move the perch up like you can on the Bilsteins.
When you say stock Bilsteins are you talking about the 5100 ? i was talking about the 6112 ( i think those are the same ones as the Bilstein TRD Pros) have not asked the dealer yet, it was leveled before I installed the shocks, so i don't think it's anything but the shocks. Balanced the KDSS, got it down to 0,5 only to come back a week later.
They are offset just like the Bilsteins as you mentioned so I would think so. Ryan from eibach should be able to answer with a definite answer.
