TRD Pro grille for Limited
At first it sounds like they’re mutually exclusive, but look... what and how the hell? Is there a shorter lookalike grill for the Limiteds? Or has there just been lots of trimming on the example on the right?
Do you mean the heritage TOYOTA part? It fits mostly fine on a Limited. I have one on mine
I want this! I am trying to do the same to my 2020 LE ... yours is a 2017? It doesn't have TSS does it? I am finding that on all sites offering the trd pro grille for 2020+ say *not compatible with 2020 Limited edition* :(
What about these?
You can still have a “TRD” (I have been corrected, it’s called “Heritage”) grille and keep your Limited bumper.
Parts PZ327-35056 for the upper mesh, and PZ323-35058 for the “TOYOTA”, no?
Parts indicate it’s compatible with 2020-2021. The grill pieces appear they are three separate things:
1.) Upper mesh (need this part)
2.) Heritage TOYOTA bar (need this part)
But
3.) Lower mesh remains in place with TSS (do not need to touch this)
It’s a 2017 yes. No TSS. I am guessing it doesn’t work because the heritage grille hangs down a bit further than the stock one and will block part of the TSS sensor
The TSS heritage grille will work on older models without it. This grille is a tad cheaper and the "notch cut out" isnt noticeable. There is a another forum on this and close up of a picture. I'm still debating if I want to go this route.
close up
Best Source For 2020 TRD Pro (Heritage) Grille
Where did you purchase this grille from. I’m looking to do the same with my ‘18 limited and all websites selling I’ve seen say not comparable with limited. Or did you just make some alterations to make it fit?
It’s OEM Toyota. The bottom of the heritage grille doesn’t touch the bumper cover so doesn’t adhere. The rest of it touches though and adheres fine. 2 of 3 sides is good enough for the last few years
You can get it from Cartrimhome with or without lights. The ones for non limiteds required a lot of trimming due to slightly different bumper shapes in front of the radiator.
Not suitable for 2020!!! For 2014-2019 4Runner 2Piece Front Bumper Grille Replacement
Not suitable for 2020!!! With LED Light For 2014-2019 4Runner Front Bumper Grille Replacement
I know everything about mine if that’s what you’re asking
Hey friend, can you post more pics about the grill please also do you have a lift kit and wheels spacer, I just got a 2014 4Runner limited I already put on it a cooper discover all terrain 275/55/20 on stock wheels with no rubber so I’m looking to lift it 2” front to look same that rear part also 1.25” wheels spacer so I really like this grill that you have so did you just got it from eBay and replace it like this video https://www.youtube.com/watch?si=zHnSqS3C5EnFocoz&v=9wyeWF7tMfY&feature=youtu.be thanks so much in advance for your help.
Miguel
Also some pictures of before and after with cooper discovery all terrain tires
Before
After
I put a pro style grille on my 18 limited. Got it off eBay for about 65 bucks. I got this one specifically because it has no spots for the Toyota letters.
Hi - Album on Imgur
I know its been a while, but do you still have that link to the one you bought? I looked on ebay for like an hour for one without the spots for the letters cause I too want it to be smooth and could not find one!
thanks
