obsfsean
Junior Member
Hey guys,
Pulled the trigger on a Toytec lift spring kit. The fronts will come with a 600lb spring rate which is pretty close to stock. I'm sure the 2.5" lift it gives in the front should be pretty doable given that Tacoma's use the same shock and get 2" of lift without any issues, so an extra 1/2" of travel should be fine given TRD has been marketing at least an extra inch or so of down travel vs stock.
Not too sure on the rear coils. I should have been more conservative and gotten a SAW 1.5" rear lift but if worse comes to worse I can always upgrade the rear shocks.
You can expect some details in the next couple weeks as I install a front only top plate spacer lift (extra inch or so in the front) paired with the OEM TRDP front shocks/springs, and the complete spring upgrade from above. I'll post measurement details and also post specs on the springs if you want to reference them for experimenting with different spring weights etc.
Looking forward to your results. I'm looking for at least a 2 inch front / 1 inch rear gain and hoping I can go the spring route instead of spacers and retain the stock bills on my trdp.
I was contemplating this found on the 5th Gen Lift Buyer's thread BEST SELLER! 3" FJ Lift Kit w/spacers and rear ToyTec coils but I'd rather go springs all around.
Question to the gurus, will these work on the trdp bills? Adjustable Front Coil Over Kit for Bilstein Shocks 2010+
