TRD Pro parts
Just did mine and very, very simple. It comes with easy to follow instructions. When installing the Garnish make sure you line up the top FIRST...I just lined the whole thing at the same time and I'm about a 1/2 cm of on one side. The adhesive is super strong and extremely difficult to remove once it's attached.
Ditto, it was super super easy to do. I contemplate to read the instruction but it was more of diagram and not much wording. I remember taking off the top part of the old grill you have to give it some force but it will be fine, just give it a yank! Just think of what you have new and what to come out, lay them out, it's quite strait forward.
good luck..
@Hook Em' Horns was it hard to replace the rear hatch panel piece off your trunk? I want to take mine off but not sure how hard it is.
Yes you have to remove the entire bumper and you have to on the front as well. Very simple, just remove all the screws/bolts and take your time with the clips.
I have done it keeping my front bumper on. I have a TEP so no extra tools were needed. Simply break down the top portion of the grill and REAAAAACH! Some clips come off from the top of the rig and others from the bottom. Your arms will probably get some light scratches and there is a technique to remove the clips.
I did it that way as there were too many screws and wires on the front bumper for my automotive skill set and overall liking.
The back bumper you have no choice. It has to come off! No wires to worry about, you have to try NOT to do what I did. Remove more screws than necessary!
Alex Grey, but close enough. Tool has been using his artwork for live shows and album art so long, people think it's Adam's art lol
I'm beginning to think we'll see the 6th gen 4Runner before Tool's new album
\m/
Really?! Totally thought it was Adams work. Nothing better than tool in the truck. Loud. Really f@#!ing loud. I'm confident on that album coming before I get my lift. Mainly because I'm not blowing my warranty or $1700 for trd shocks/springs
TRD Streetlock Rims
Anyone have any weight info on these wheels?
PTR45-35010
Also assuming yes but can they be run without the bling ring (i guess I would find shorter screws to fill the holes)? I run hot and cold on the look of the ring.
Sorry for the delay, meant to reply and then forgot..
It was pretty easy, just gotta take ur time. These links saved my arse:
Components : https://www.dropbox.com/s/rdfaegzkyk...NENTS.pdf?dl=0
Disassembly : https://www.dropbox.com/s/1cs3iog72b...EMBLY.pdf?dl=0
Installation: https://www.dropbox.com/s/ilp5z82wiu...ATION.pdf?dl=0
Reassembly :https://www.dropbox.com/s/wr8n2bjpa9...EMBLY.pdf?dl=0
Removal : https://www.dropbox.com/s/t3gzd16wez...MOVAL.pdf?dl=0
\m/
Not having a whole lot of luck with any of those links..
any other advice?
\m/
any other advice?
Oh wow, sorry about that bud. When I was stuck, [MENTION=28870]d_clark[/MENTION] helped me out with those links, which I guess only work if you have a Dropbox account.
On my iPhone, so will post individually..
Components:
Man, I really want the TRD skid plate for my runner. I wonder what kind of modifications need to be done to make it work with my TE equipped with KDSS ;-(
I don't know if you ever got your answer, but the rear upper part of the skid plate on either side of the skid plate (part that is vertical) would have to be trimmed. Would actually be pretty easy to do.
Yup pretty easy to do. im actual going to be doing it soon ;-)
Drivers side lean
[MENTION=45171]vinnysrunner[/MENTION],
There are posts that indicate the part # for the individual parts, if I read them correctly.
Shocks
Front:
Left-PTR13-35120-AB Price: $329.17 Each
Right-PTR13-35120-AF Price: $329.17 Each
Springs
Front:
PTR13-35120-AA Price: $115.16 Each
Thanks...
I have this setup (minus the 5160's, I have 5100's), and I've come into a little problem. I recently took off my factory step sides and I noticed my drivers side (front & rear) has a significant drop/lean than my passenger side (maybe an inch or more).
at first I thought there might be two separate shock numbers (PTR13-35120-AA for a driver and passenger side), and then I was thinking the 5100's aren't seated correctly (1.75 bracket/3rd ring).
I'm open to your to your suggestions and professional opinions.
I was also following the following thread [MENTION=46345]Jester4kicks[/MENTION] but as these TRD Tuned springs are more relevant to my problem (http://www.toyota-4runner.org/4th-gen-t4rs/107699-drivers-side-sagging.html#post973566).
Will all the info in this thread, especially about the 2015 trail editions with kdss skid plate, correlate to a 2016 trail edition TRD skid plate installation? thx
there's no difference between a 2015 and 2016, if that's what you mean.
if you have KDSS, you'll have to trim/modify the TRD skid and remove the lower radiator supports to make it fit.
premiumusedautoparts
