TRD Pro/Trail Hood Scoop Insert Removal & Paint
Anyone know the difference between these parts? I've seen different posts on the "Pro" hood scoop mod reference one or the other, which is correct for the TRD Pro?
76181-35080 Bulge Hood
76181-35902 Scoop
great info. would you happen to have the part number for the black screen :thumb3:
I went the "over-paying" route. It was approx. $75 online out-the-door for all 6 parts.
"Hardest" part was getting the plastic clips out that hold the under-hood liner in place. I used trim tool to get them started and then use needle nose pliers to get them the rest of the way. *Tip* - Hard to see but there are tiny little circle marks on top of these clips that indicate orientation in which you need to grab them.
Once liner is off, use 10mm socket for the 4 nuts. Then undo the 2 blue clips and then the center orange clip using needle nose pliers. Pull old insert off hood and then pop out original screen pushing the 4 tabs down gentle on the back side.
Insert screen on new hood scoop insert. Using old insert as an example place/stick new "seals/protectors" on new insert.
Put everything back together and done.
2019 TRD PRO Black Hood Scoop Insert Part Numbers
Qty 1 - 7618135080 (Black Hood Scoop Insert)
Qty 1 - 7618535030 (Seal/Protector)
Qty 2 - 7618335030 (Seal/Protector)
Qty 2 - 7618335040 (Seal/Protector)
(Not included is the black screen since you can re-use your original one)
i believe these are the differneces
76181-35080 Bulge Hood - comes finished in black for trd pro 2019
76181-35902 Scoop - comes unfinished black for painting
76181-35902 Scoop
No prob! Post a pic if you do it...I'd love to see this on the quicksand.
I finally did it. I had to put a decal on the hood scoop b/c of the glare, and so added the vent to make it look better. I don't think I like how it looks but what else to do about the glare?
Did mine today. My bolts were 10mm, not 11. Thanks for guide!
So I posted a few pics in the 'TRD Pro' forum of my hood scoop insert, that I recently removed and painted satin black. I've had a few members PM me and ask for the removal process, so I've listed the steps below. It is pretty straightforward, with just a few precautionary items.
First, Here are a few pics of my TRDP with the mod (not to be obvious, but it used to be white). To be honest, I was inspired by the Bushwacker 4R shown on their site...and yes, my next step is to install the fender flares :wink2:
Okay so now on to the removal process. All you will need is a pair of (small) needle-nose pliers, and an 11mm socket/wrench.
Step 1: Remove the hood insulation pad. There are 10 plastic rivets that hold this in place (circled in red). Start with the rear of the hood, and work your way up to the front, allowing the two inserts (circled in blue) to keep it from falling out on you. Tip - do not try and pull the rivets out...you will break them. There is enough play that you can actually wiggle the needle-nose pliers under the head of the rivets to grip their necks, allowing you to compress them so they come right out. The necks only compress one way, so you'll have to turn them a bit until they feel them disengage.
Step 2: Once the pad is out, remove the four 11mm bolts.
Steps 3/4: There are three plastic rivets with ears (one orange in the center, and two blue on the sides). Grab the orange one with your pliers and turn it counter-clockwise. It will turn just enough to clear the ears from the hole. Then, insert your pliers through the hole far enough to (gently) grip/compress the ears on the blue ones. Apply a small amount of upwards pressure, and you will feel them release. Be careful, the blue ones are a bit flimsy.
View attachment 221438 View attachment 221439
Step 5: The insert is hinged on the back. After you complete the above, simply lift from the front and pull it out. Once it is out, you can remove the thin 'faux grill insert' piece, by compressing the 4 tabs on the backside of it.
Easy-peasy. Now you are ready to mask, and paint. I tried plasti-dip (my first time messing with it) in my garage, and it yielded dismal results. I followed all instructions (light coats at specified distance), but it seemed to flash before it made contact with the insert, leaving a sandpaper-like texture. I attribute this to the heat/humidity in Houston, I guess. I peeled it off and took it to my buddy's place, who has a small paint booth (I used PPG Satin Black, and it matches the front grill to a T). Once you're all done, just reverse the steps above for the install.
I personally, love the look against the white...but think it would look killer on any color TRD Pro (or blacked out trail). On a side note, I also painted my roof rails the same satin black - I thought it was ridiculous that Toyota did not do this to begin with (along with the rear lettering). Happy trails!
Scoop
Thanks so much. Just got mine installed using your helpful instructions.
