TrekLights LED Light Bar Group Buy
Each light is shipping with a switch and a fuse holder. Relay and wire gauge is up to your personal preferences.
Yes, those switches should work. I've had my eye on the Zombie Lights version for a while now :)
If anyone is looking for a pre-built harness, I recommend this one: Low Beam: 9006/HB4 - Relay Harnesses from The Retrofit Source Inc
Paired with these (or similar) connectors: 9006 Female Wire Harness Connector Plugs Hella Ballast | eBay
Hello Sir,
I've been looking at your lights and like what I see. I have a question about the wiring set up...I looked at the links you posted above. So, are you saying...the e-bay connectors will plug into your lights...then you connect the retrofit harness
to the e-bay set up? Will all the plugs plug into each other for a factory look? Or do you need other connects? If so, where do you get them from? Or, do I back that backwards? Thanks for your time...
Russel
Hey everyone!
Sorry I've been scarce for the past couple of days.
Been catching up on family time, 9-5 stuff, and TrekLights stuff.
Back now, and responding to all inquiries!
Hello Sir,
I have a question about the wiring set up...I looked at the links you posted above. So, are you saying...the e-bay connectors will plug into your lights...then you connect the retrofit harness to the e-bay set up? Russel
Correct.
Will all the plugs plug into each other for a factory look? Russel
Yes!
Or do you need other connects? Russel
Some heat shrink tube and wire connectors to connect the bare wire from the light bar to the ebay connector will give your work a nice, finished look.
If so, where do you get them from? Or, do I back that backwards? Russel
Home Depot, Lowes, Sears Hardware, any hardware store really.
Thanks for your time...Russel
It's my pleasure, Russel!
All invoices sent to those who PM'ed me their email addresses!
If you have not yet received an invoice, please PM me with your email address and I'll send you one.
-Troy
I prefer to do as much "one-stop" shopping as possible. It appears that The Retrofit Source carries harnesses like the eBay link:
Common Connections - Accessories from The Retrofit Source Inc
Would the configuration below be correct?
End: Female
Format: Pre-Wired Pigtail
Thanks,
Hung
Hey everyone,
If you haven't already, please PM me your email address so that I can send you an invoice.
-Troy
Hey Troy
You may have done this already and I just cant find it. Can you post a picture of the connection end of the wire ?
Hey Troy
Thought I did, but I didnt.
Here you go:
Just a pigtail, which is why the 9006 connector and harness are good idea if you're looking for a no brainer installation.
For those still deciding, like myself, this may push ya off the fence......lol
Trek Lights 18" XT LED Lightbar (Spot) - Tacoma World Forums
Did anyone inquire as to where these lights are made? Have any failed or been returned for warranty. Where the components are made and the lights assembled. There are alot of options on the market today, IMO some good and some not so good. I tend to stay away from China products, unless they are proven in the market. Since the business is new, I'd like to know what I'm getting when I purchase a Treklight. Having said that, I really like what I seen so far and hope to place an order soon.
Hopefully, Troys phone not swimming with the fishes again. lol
Hope the review helps..........
Regards........8sm
I never questioned where the products are made. That is a good question.
I looked the product over in the pictures and I dont see any marking.
I am sure Troy will respond.
Regards........8sm
Hey all!
No my phone isn't swimming with the fishes (haha), just working on a big project for my 9-5.
As far as where the lights come from, here's a break down:
For anything with CREE LED's, the diodes are made in the USA, then shipped to China for assembly into the housing.
For anything with Epistar LED's, the diodes are made in Taiwan, then shipped to China for assembly into the housing.
I've spent lots of time researching the best manufacturers of these lights, and I have someone on the ground in China who does sourcing for me. I believe that I've found the best supplier out there.
DJNutshell
