In the middle of installing an airlift kit. Directions seemed to indicate the bumpstops are cut at the first 'joint', basically leaving the bumptstop a flat disk sitting on top of the spring. Then the directions seem to indicate with it's diagram that the first section of bumpstop is left attached and airbag is touching both the bumpstop and lower disk included with kit.
I've cut at the first joint from the top, but would prefer not to put it all together if there is supposed to be one section still left on the stop (and can get more oem bump stops if needed).
Everything I've found searching just says cut the bumpstops, apparently I'm the only one confused with the directions dammit.
Appreciate any insight.
