and perfect for those MultiMode trucks to run AWD in the snow, ice
I wonder how they act with a standard (non AWD) transfer case 4runner in 4wd.
Do you feel front end bind when the center diff is locked?
Alright, so I'm trying to get these answers on three different forums but its all the same people! Pretty funny how big this community is and how small it is at the same time!
So....next question is where do you get pricing on the trutrac?
Thats a good point Brian. The first question I thought of when I read that was how much does a CV axle cost? I haven't had one break yet probably due to the fact that I don't wheel that hard for that long...but the ARB solution is $800+ more than the trutrac. So how many times can you break CV's before you break even on the ARB? Of course, there's the whole inconvenience of breaking stuff on the trail...but without that consideration...
Haha...well I can't count on getting such a deal on the ARB! Good for you! It's all a trade off I guess...I guess it's just sad that the only real choices if you want to be able to drive it on dry pavement is Trutrac and ARB...at least thats all I've found.
Well, you could do a lunchbox locker (aka Aussie or Lockright) in the front and they are ok to drive on pavement in 2wd. They won't lock up if there isn't any power going to the ring and pinion. But once you put it in 4wd, it will try to lock up whenever you give it gas so steering in 4x4 will suck whenever you're on the gas.
Thats why I ruled those out. I really have to be able to use the 4wd in the snow or ice so a lunchbox locker wouldn't work. Thats why I mean ARB or LSD are the only real choices...
Yukon should have a Zip Locker available for the 7.5 in a few more months. Its basically an ARB knockoff that is $150 cheaper. I have installed several 8" versions into customer's rigs to date with good results.
One thing I considered when deciding between the ARB and the Trutrac was the stress they put on the components. While it's true that a an ARB fully locks the diff (becomes a spool) and that is harder on the CVs and everything, it's really only that 1% of the time, in those really sticky situations that it's in the "danger zone". The other 99% of the time, it's fully open so no different than stock.
What hasn't been mentioned and why I chose the ARB over the Trutrac is that the Trutrac doesn't fully lock so you run less of a risk of snapping a CV or other damage when your in those 1% of the time, hairy situations (like mentioned above). What wasn't mentioned was whenever you're in 4x4, the Trutrac has more resistance and puts more stress on the components. Yesterday for instance I was in 4LO for ~6 hours straight, but My front diff was open the entire time because I didn't need it locked for the wheeling I was doing. However, if I had a Trutrac up front, I would have been putting more stress on my components the entire time. Whether it's enough to break a CV in a day or 2 of off roading, I don't think so. But the stress it creates, especially in 4LO, over time can't be as good as running your diffs open.
