TSBs at NHTSA
I went thru all the TSBs listed on the site I posted for my 2016 and found only 3 that looked worth knowing about. Many were basically telling a dealer how to respond to a customer having problems with entune, particularly smart phone updates causing problems.
March 8, 2017 MANUFACTURER COMMUNICATION NUMBER: T-SB-0033-14_REV
Components: EQUIPMENT
NHTSA ID Number: 10131861
Manufacturer Communication Number: T-SB-0033-14_Rev
Summary
TSB: REVISION NOTICE March 08, 2017 Rev1: ? Applicability has been updated to include 2015 - 2017 model year Toyota vehicles. ? The Parts Information section has been updated. Some vehicles in particular geographic areas may exhibit a condition where the HVAC Evaporator Drain Hose has become obstructed with an insect nest. An insect repellent drain hose tip (ARINIX® Tip) is now available to help minimize future occurrences of this environmental condition. For some models, a new drain hose is required to properly fit the ARINIX® Tip. Follow the procedures in this bulletin for proper handling and installation of this optional service part.
October 25, 2016 MANUFACTURER COMMUNICATION NUMBER: T-TT-0424-16
Components: WHEELS
NHTSA ID Number: 10132884
Manufacturer Communication Number: T-TT-0424-16
Summary
TT: Front Brake Vibration Key Points: * Issue can occur at any time if improper torque is applied on lug nuts * Over time, even one lug nut over or under torqued, can cause a vibration issue * When lug nuts are over torqued, this causes the rotor to have a runout out condition which can lead to brake vibration concerns * Brake vibration issues can occur at parking lot to highway speeds * Brake vibration issues can occur at light to moderate braking * Tightening lug nuts in a star pattern method during the torqueing process will assure that even/equal pressure is applied across the rotor hub surface * Torque sticks/wrenches should be used to apply accurate torque values when tightening * Do Not use impact guns/ratchets to completely run lug nuts up to the wheel surface
June 8, 2018 MANUFACTURER COMMUNICATION NUMBER: T-SB-0026-15_REV
Components: POWER TRAIN
NHTSA ID Number: 10142876
Manufacturer Communication Number: T-SB-0026-15_Rev
Summary
TSB: REVISION NOTICE June 8, 2018 Rev2: ? Applicability has been updated to exclude 2016 ? 2017 model year Tacoma vehicles.
? The Repair Procedure section has been updated. May 15, 2017 Rev1: ? Applicability has been updated to include 2016 ? 2017 model year Tacoma and 4Runner vehicles. ? The Introduction section has been updated. Any previous printed versions of this bulletin should be discarded. Some 2004 ? 2017 model year 4Runner vehicles, 2007 ? 2014 model year FJ Cruiser vehicles, and
2005 ? 2015 model year Tacoma vehicles equipped with part-time 4WD may exhibit a cyclical groaning or grinding noise coming from the front differential in 2WD that goes away when operated in 4WD. This noise can be addressed by replacing the needle bearing on the left side of the front differential. Refer to the Repair Procedure for needle bearing roller replacement instructions.
Going to ask about the evap drain next time I get service
charlesz
