Tundra/8 wraps rake, anyway to raise front more?
zRus13
I have tundra coils with bilstein 5100s on 3rd perch and LC 8 wraps with billy 5125s, it has a rake to it nothing huge but you can notice it. Is there anything I can do to the front assembly like a spacer of some sort to help level out the rear. I like the height in the rear and didn't know if there was a fix to the rake
Im thinking about doing a partial bodylift Witht the front being higher only, to compensate for the back, but i havent decided yet.
I love the rake look as long as its not over an 1" higher in rear. My rear is exactly 1" over the front and IMO is perfect. When I weigh the rear end down she levels out. I would rather have rake and level look when loaded than the rear sagging when loaded without the rake.
Another option would be to get some new bumpstops (the kind that go outside the spring) and get rid of the cone bumps. That would lower your rear just a little bit so the difference doesn't look as much.
I agree the rake is a good look, I was just curious if there was any option to make it level if I ever want to in the future, I'm used to the rake now and its about a lnch so it looks perfect.
You could do a small spacer on top of your coils. ToyTec has some that are for 1/2" and 3/4" lift. I wouldn't go over a total of 3"
You could use higher perches on the Bilsteins.
With any of these you run the risk of greater angles on the CV joints and premature wear of them, along with cracked boots.
I am not into the rake on my truck but I'm not sure there is much I can do about it now. More evident on pavement but...
I was looking at the spacer, honestly it's not that terrible of a rake I was just looking at my options
