[MENTION=163055]psea17[/MENTION] the Denso unit from a Suzuki Grand Vitara is a bolt in upgrade. You might have to drill a new bolt hole in the mount? Not sure but keep digging. I think [MENTION=112124]ToyotaBrah[/MENTION] can elaborate.
From Crudrunner on TacomaWorld:
“3rd gen 4Runner, just replaced my dying stock Denso Alternator with the Grand Vitara DENSO2100461, so far stoked on it.”
Source:
1st gen 105 amp bolt in alternator. | Page 15 | Tacoma World
Great Recommendation. Reading up on it now. Looks like you just drill out the hole where the adjuster bolt passes through the alternator bracket. Easy.
Source:
You need to watch your wire gauge on the wire that goes from the charge post back over to the fuse box. Not only that but The fuse that drives it. You go above the late model 01 and 02 higher cap alt.. You are going to have to do some modifications to the system. Maybe you are aware of this. I just wanted to mention it.![]()
Thanks for bringing this up. It is not a good idea to put a 105 amp alternator in with the stock 100 amp fuse still in use. If that fuse blows you're dead in the water. I know that 96-98 have the 100A, can't remember if 99-00 does as well.
1996-1998 alt fuse 100amp
1999-2002 alt fuse 120 amp
If anyone exceeds these amperage the fuse is going to pop.
This is why I never really understood these big 3 upgrades??
Unless your changing the engine swap with v8 etc yes.
If you want a bigger alt you watch your charge wire and fuse that drives it.
you need to modify the wire gauge as well and a higher amp fuse.
I suggest that if anyone goes over 120 amp ( on 1992 to 2002) , or 100Amp on the (1996 -1998) I would upgrade that wire and fuse and then that wire from the fuse to the battery as well.
This is just to add to gamefreakgc information.![]()
I did the Big Three in a way that keeps the stock alternator wiring and adds a second one. That way there's now two positive power wires, one is fused at 100A and the other 120A. The way the power flows it'll always flow evenly between the two so neither will ever see the whole ~130A from the CS144 alternator, more like 65A tops per wire, if that makes sense.
Sure it does. As electricy takes the path of least resistance.
Now if your running a pile of accessories then yes a 2nd fuse box.
Then a 2nd wire to the accessories box and 100 Amp fuse powering your 2nd box. With a 2nd ground to those circuits. That's what the larger alternatures would be good for.
I can see this in 3rd gens used for winches and camping accessories. As they need more energy.
I just hope those upgrading to really high Amp alternatives are understooding what they need to do. I just not want to see folks blowing fuses.
Sent from my SM-A505U using Tapatalk
Excellent point. They are fairly open.My only reason for exploring the CS144 upgrade is the design of the alternator itself. I am on my 3rd alt in 2 years, always failing after playing in the mud. THE Toyota Alternator is WIDE open and packs up with mud and water easily. The CS144 is a closed case in the front that should theoretically prevent as much mud and debris from fouling the diodes and brushed....
Good eye -
I was going to install the quality power 105 a few years back until I got to thinking about the above. Ended up going back to a new stock one. Wasn't too keen on chasing each thing that would burn out because of the increased volt/amperage.
