I just tried looking up "more aggressive pads" but was unable to come to ANY definitive conclusion as to WHICH more-aggressive pad to use.
Do you have a specific recommended pad that I can start with?
I looked up the ATE (apparently pronounced Ah-tay') "superblue"; this is a pseudo-DOT4 fluid apparently (it's only not true DOT4 from what I read because the DOT spec apparently actually cares about the color not being blue) and already ordered two liters and a pressure bleeder.
When you do a pressure bleed, do you have a seat-of-the-pants feel for how many liters are needed?
Hawk has a HPS pad which is more aggressive than OEM pads. Take a look at Tirerack.com and see what they have. Also their Hawk HP Superduty is a little more aggressive.
Brakes for 1997 Toyota 4Runner 2wd
One thing to note, the harder the compound and better the braking sometimes translates into more brake dust on wheels and some squeal. Nothing to worry about, just wash the wheels off more often and just ignore the squeal if you have it.
When I use Hawk HP+, (also, Carbotech, or Cobalt) track pads on the street (usually a little after or before track events with the RX-8) I've had folks come to me and say that I should check my brakes because it sounds like I need to change my pads. I just say thanks and keep going.
If you're going from normal amber colored brake fluid to ATE Superblue, just bleed your brakes until you start seeing the full blue come through. Then you know you've gotten the old stuff out. Start with the rears, then the passenger front, then the driver's front. You want to go furthest away from the reservoir to the closest.
That's one thing about the ATE, it comes in amber and blue. Its the same stuff. You can alternate from one to the other every time you flush to make sure you have complete new stuff each time. Not that I think you'll need to reflush, but in a race/track car, you flush brakes much more often then a normal street car. I'm sure your brakes haven't been bled in a long time, you'll be able see see a darker brown fluid more than the amber.
