Yaa I did the manual brake bleeding on it with my girlfriend if I did blow a seal or anything won't I loose brake fluid??
The fluid would just leak past the piston seals back into the master cylinder reservoir.
Did ya'll ever fix your soft peddle problems? I just did the tundra 231 swap on my 2000 4runner and am begginning the process of troubleshooting.
I did 2-man bleeding. Pumped 40x with key off until depressurized, turned key on, wait for pump to stop, pump approx 20x, then press and hold pedal, crack bleeder until no bubbles, tighten, release pedal, repeat. I did in this order: LF, RF, LR, RR. Maybe I should return to the front, and/or adjust the rears. This is a manual adjustment in the drum case, right?
