Tundra Coilovers
BFEATHER2008
I just got a set of non trd coils from work from doing as tundra frame customer wanted new stuff he got quick struts from monro. My question is what is the difference between non trd and trd coils? the color codes are yellow/green and light blue/ green. can anyone help me out this ive had heard already that the only difference may be they are not a progressive coil.
As I said in the thread that is linked the differences are a Progressive (TRD) v. Non-Progressive coil and lift heights. The TRD coil also provide a bit more lift than the non-TRD coils. I'm not sure what the difference is, but 4wd & 2wd does have a factor in it. Also I believe Access Cab and Double Cab makes a difference, but I don't know what height differences (if any) it creates.
I got double cab off an 06-07. Still waiting to find lift measurements on someone who did access cab springs on the bottom perch of Tundra 5100s. My results are documented in my build.
i hope you got them for an 06, because if they are for an 07 then you got hosed... there is no way those will fit
they came off a access cab 4wd 2000 tundra.
You say that now......
i just to get it lifted and then ill prolly get the trd coils. They are 110.76 my cost new through toyota. and i would buy new just cause i have the discount and i dont have the money right now for that and plus these coils were FREE so i cant complain when there free. And besides my truck rides rough than my dads chevy 2500hd duramax. a lot rougher.
Mike Sargent
