cj80cruiser
Senior Member
Is anyone aware if all Tundra TRDs from 2000-2006 have the blue/blue and yellow/blue spring codes? I'm sure thats what you get when you get a TRD but I wanted to check and be sure first.
How about Red/Blue? What code is that from?
Check these out, I believe they were from a 4x2 Tundra TRD:
Texas FS: TRD Springs and Bilstein 5100 !!!!!!!!!!!! - Toyota Tundra Forums : Tundra Solutions Forum
As per this link (New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner! - YotaTech Forums) on Yotatech,
"Tundra TRD 2WD Front Coils
I used 2WD TRD Tundra front coils but everyone else have used 4WD TRD Tundra Coils. All use Extended Studs w/ some HDPE 3/8" Top Plate Spacers and the lift amounts are almost IDENTICAL. The added weight on my rig is about 100# MORE when compared to a stock runner, yeilding about a 0.20" drop in my ride height overall. The conclusion is that the 2WD TRD and 4WD TRD Tundra Coils are essentially the same when installed on a 3rd Gen 4runner."
Im thinking of picking these up, they arent the typical y/y, y/b but I am assuming the Yotatech article is correct regarding lift heights as he seems to have run several setups.... someone correct me if im wrong.
does the y/y or y/b go on the driver side when installing?
I was under the assumption that all TRD tundra springs are progressive. I wonder if Anyone has tried these? I am getting a bumper in the next 6 months....
