Tundra TRD Spring/Shock Swap Actual Lift Height?
OldSkoolArcher
Please post up actual lift heights gained by using the Tundra TRD Spring and Shock Combo on their 3rd Gen.
I am planning on using them on a '98 but have read a bunch of different lift heights. Lift info and faq post states 2.5" but I have been reading as much as 3.5". Thanks In Advance.
I started with stock shocks/coils and 2" spacers in front. When I switched to Tundra coils and OME shocks I gained about .5".
Are the ones reporting a 3.5" lift using a top out spacer? That may be the difference. Also could be the year 4runner they have. Not all 4runner factory lift heights are equal.
I asked the same question a while back and the consensus was 2 inches for that thread. Other factors include your current ride height (some 4x4's being a bit higher than 4x2's) and how many miles the Tundra coil assemblies have.
Expect 2 inches, and be stoked when you get 2.25!
I am not sure if guys getting 3.5" of lift are using the top out spacer or not.
I would be stoked if I would get 2-2.5" of lift outta them. I am worried about them yielding more than that and being too high for me actually.
If they are too high then get another set from a tundra that arent y/y y/b and they will be shorter. You could sell the other ones on here I would think with no problem finding a buyer.
And here's a link to a thread that may also help you
http://www.toyota-4runner.org/3rd-gen-t4rs/70946-finally-got-my-lift-parts.html
This is a tough question. Almost every year sat at a different height from the factory. The difference is all in the springs. The height of a "lift" coil in a 99 or a 2002 will yield a different amount of lift.
toyodajunkie
