Turn signal
Craig5416
The signal/DRL on the front drivers side of my 05 4runner is not working.
I replaced the bulb but that did not fix the issue. I also checked the old bulb, it does not appear to be burned out. I checked fuses (in the truck and under the hood) and looked at the wires everything appears to be in good order. Has anyone had a similar problem.
Or have an idea of what might be up.
Sorry forgot to mention that. The only light that is not working is the front drivers side. The rear light is working fine.
Last time when one of my front signal light was out, my rear signal light (including the one on the dash) would flash faster than normal. All i had to do is replace the bulb. Are you sure you have the right bulb?
I've had both front turn signal (and DRL) lights go out in my 03 over the years. What I remember from the last replacement (a few months back) was to make sure the new bulb is pushed fully into the socket. It is a really snug fit, and you have to make sure it is pushed in all the way. I thought I had the new bulb in, went to activate the turn signal and still got nothing. Pushed on the bulb a little hard, and felt a click with the bulb/socket connection - turn signal and DRL working fine after that.
Thanks Bossman. I just went out and checked the bulb wasn't in all the way. It clicked once like it was in place, then clicked a second time to seat the rest of the way.
Tx470
