Two new master keys - $225
scottm
They charged me $90 for programming, because they couldn't remember how to run the machine. But it can be done: when you lose your keys they can make new ones without a master.
Better to pick up a blank or 2, have them cut and then program them yourself (assuming you have your 2 original keys). I don't believe my T4R Owners Manual tells you how but I can do it with my Ford and it's described how in my Mustang's OM. If a Ford can do it then a Toyota can do it. Gotta be a better way than paying that kind of cash.
I looked into it, apparently you need a computer with the right program and hookups to program a new key. Without a master key, there was much speculation that I might need a new ECU ($!!). As it was, they needed to do some extra farting around to program new masters without the old master key. They said on some Toyotas, you need a new ECU if you lost all the master keys.
I think if I'd had a master key, I would have kept looking for a hack or shortcut to program a new one, there's got to be a way. I've heard locksmiths can do it if you have a good master.
One of these keys has a lot of burrs left on it, I'll be hitting it on a diamond wheel at the shop later. Don't need to tear up my tumblers next.
Thanks for the update. Seems that the TSB we referenced in the other thread may be obsolete, or the information is different for newer models.
Luckily for me! I took a big chance buying this truck nobody else wanted, it's nickel-and-dimed me some, but I've dodged some expensive problems. I'm sure to be back with another discovery as I get into and under my new project.
The dealer I bought mine from last year charges me $160 for two keys. I thought THAT was bad!
BillM777
