txbonds
Senior Member
Radflo passenger coil over in place. Lower bolt nut torqued to 70 ft lbs per the FSM (TIS Website). Upper 3 lock nuts tightened snug without torque setting per the Radflo instructions.
Camburg UCA installed using factory bolt and Camburg supplied hardware. Torqued to 85 ft lbs per the Camburg instructions with red loctite. Had to move a hard line forward to get a socket on the nut.
Need to tighten ball joint and reinstall the hose line brackets and bolts to the knuckle next.
