sschaefer3
I had a floor jack and cribbing under the piston. I did passenger side up first as you have the most movement, leaving it "finger" tight. I then grabbed a ratchet strap and went over the lower a-arm and back to the frame and simply ratcheted the driver side of the swaybar up until I could get and alignment punch in to match it up. Torque everything and go. Piece of pie
[MENTION=95329]txbonds[/MENTION] [MENTION=1795]sschaefer3[/MENTION] thanks for the info on the panhard bar. That's rich, I don't think I have seen anyone mention this in all the suspension build threads I have dredged through, not to say that they aren't there, just hadn't seen them. On that note I would like to get a 1.5 SAW springs in the rear, is that enough to warrant one of these? I imagine you could add one at stock too since it is adjustable? Thanks
Those sliders are a trip, interesting concept, and wonderful tight fit. I guess my only concern is road grime (ugh salt) getting between the slider and the pinch weld, I would be curious to know how much if any gap there is for clean out.
1.5" of lift is not going to warrant a longer bar. But the real point of the bar is more axle movement, so if you are installing longer rear shocks or want the most movement out of the rear axle that is what the part is for. Total Chaos and Icon also make adjustable bars with unlimted movement ends. Those use Heim joints which will wear quickly in rust belt weather, ours uses Poly Bushings. Which are inexpensive and replaceable.
As for the sliders and corrosion. I have been in the business since 2001. I am amazed at what the weather in New England and the Rust Belt and Canada does to metal. Even one of my 3rd Gen 4Runner rear bumpers in Colorado that was powder coated and sand blasted very clean right after building it, before powder coating rusted out. Icon, King, Radflo and all the other So Cal coil overs are going to rot out in these environments as well. A frame mounted slider is going to collect as much crud between the plates/frame and corrode too. Everything metal is going to corrode. I don't really think there is any great solution to rust proofing. Factory Toyota wheels I have seen in Massachusetts are crazy corroded. But I would say the Sleekester Sliders are a Down South and Out West oriented item, just like the coil overs I mentioned above.
