kregg
sry that im not as talented as you.......................not
Talented? How about "educated"... Walk out to your truck and look at the suspension components. Find something that resembles a U-Bolt or a leaf spring.
And 13 seconds after clicking search...
the way we got them out was to get a deep socket with wrench on the nut up top and hold the wrench in place, then the other person had a huge pair of channel locks and turned the upper part of the shock to loosen the nut.
I put a socket on the top nut, cut off the dust shield and turned the shock shaft with vice grips. Takes forever but it works...
Only access is from the bottom and it's all by feel. When I installed my lift I used a ratchet and socket and had a buddy hold it while I turned the shock itself. Use a lot of lube on the nut, just put the straw on the tip and spray. Also removing the wheel will help. Hope this helps
And for your lift options...
Courtesy of Pikeman -
1. What will the usage of your vehicle be like? percentage of street and off-road
2. What type of off-roading? Fire-road, mud, rocks, desert
3. What is projected budget you are willing/ able to spend?
You can get a complete OME set for around $700 good for daily driver and mild/moderate off-road
Toytec Ultimate Lift with Coil-Overs about $900-1000 good daily driver and moderate to heavy off-road
Sonoran Steel various kits up to $1500 the SS1.2 decent daily driver with heavy off-road.
The two most knowledgeable stores with 3rd Gen Runners would be Toytec Lifts and Sonoran Steel Custom Metal Fabrication L.L.C.
:keyboard::nerd:
