UBJ going out?
I never had any luck yanking on the wheel to check things. If you really want to know what is loose, Jack the frame, Take off the wheel and sway bar link and take out the bottom shock bolt. This takes all the tension off the control arms and ball joints and you can really see what is loose
Mine made a noise like this. I had replaced my sway bar end links and the connection to the frame was loose. Sitting still it looked tight. but when I turned or hit bumps, it would move in the frame hole. I had to get that thing really tight to stop it. Also, check the LCA lock bolts. I had an alignment and the tech didn't get them tight enough and whenever I pulled out of my driveway I could here a "clunk" sound. Those bolts have to be pretty tight too.
Damn... I'll bet that's it! I replaced the end links and bushings, but I used parts from Rock Auto and they look like shit already. I'm going to put some good ones on when I get it home and see if that's the problem. I wasn't happy with what's on there anyway. Thanks!
