UCA question??
06SPRTRUNNER
i am installing the daystar lift on my 4runner and i was wondering if i needed to get new upper control arms??
any help would be greatly appreciated
thanks Taylor
Check out the suspension sticky at the top of the 4th gen page. If you stick with the same tires, you will not need new UCAs
I got daystar with no arms and i'm fine. Just can't run too wide of a tire. I think anything over 285 needs either a spacer or UCA but check out the sticky. Anyways moral of the story, you don't need UCA.
I have the Daystar lift and did not change out the UCA. I do feel a little float in the steering but nothing to be concerned with. My Frontier was the same (Revtec spacer lift) and I drove it 50,000 miles with no issues.
When I change to a coilover lift I will change out the UCA. I did on our FJ and the steering is tight.
Thanks guys! i changed out the UCA when i did my coil over lift on my tacoma and the steering is better than stock. when i upgrade down the road to a coil over on my 4runner i will change them out. thanks for the input guys
patnewton
