UCA spindle nut backing out
Motory
I just installed a set of billet uniball UCAs. I know creaking and squeaking is extremely common with uniballs and mine started after about 1000mi after a trip. It doesn't bother me that much, but I noticed the lock nut (doesn't use a castle nut and cotter pin anymore) that holds the UCA to the spindle has been slightly loosening - I've had to retighten it on both sides. It's made me a little skeptical to drive the car because I'm afraid it's going to back out all the way mid-drive. They're pretty much brand new so I can't see how they'd be binding up already - i'm going to hit everything with some tri flow, but I'm confused at to what could be causing this or how to fix it.
Contact the manufacturer for their input, they designed it, should be able to help you out.
albertpeter156
