Under hood part identification help 1996
Dezerts10
What are the little modules that he arrows are pointed to?
I’m working on trying to figure out all the crap I can remove from the inner fender or atleast working on figuring out what I need to move to cut the inner fenders out
I think the bottom is part of the ignition system, top I'm not sure. Should be a part number on it, find it and google it or follow the wires to narrow it down.
8962135020 IGNITER ASSY
takes low amp and steps it up for the ignition coil. no explosion no fun, this is needed for the explosion.
Looks like the other item is the abs traction control relays. They will be ditched along with the AbS module. Other stuff will move easily.
Now the other side looks alittle more involved with the charcoal canister and fuse box and a ton of vacuum lines
H.Sikina
