Undercover fridge?
Rotorgeek
Hey all,
I would like to get a fridge but I want to try to keep it under the factory cargo cover. I usually solo but I like longer trips and I hat all the ice issues. Size and brand are less of an issue than stealth but I still want the largest one that will fit. I'm looking to see if anyone has pics of the back of the truck with a similar setup.
Must:
Fit under factory cover.
Use factory d-rings for tie down or bolted slide tray.
Bonus if:
I can still use 2 of the 68qt Plano boxes next to it.
Slide tray.
Dual zone, because are we monsters? Who dosent want cold beer AND ice cream!
I have a portable battery and solar for power but I will add a second battery in the truck soon.
Edit: 2016 Trail, no sliding tray or 3rd row.
Concerning fitment:
If you want to cover your fridge then retract the cover to open the lid you’re limited to the height (about 18-19 inches). And the length of cargo hatch door to the cargo cover’s spool (about 27 inches).
It looks like the three smallest Dometics will fit properly. You might be able to go with a longer model if you incorporate a slide, and take into account its height off the floor. There’s enough slack in the cover where it will “stretch” a little over a ~20 inch height.
https://epi.dometic.com/externalassets/dometic-cfx3-35_9600024617_77453.pdf
Taking a look at Dometic, based on width dimensions, the biggest one you could fit next to two 68 qt plano trunks would have to be 15" wide or less and that's the CFX3 25. Each plano is 14.25" wide and the cargo area is 43.5" between the wheel wells. The 35, 45, or 75 should fit height wise under the cover. I have the CFX3 75DZ and it's the same height as the 45. Length wise it also fits in the cargo area with the second row seats up so that's a plus.
ghengiskhan
