upstream 02 sensor for 2000 4runner california
kand3g
I purchased a new 02 sensor and at the time of installation realized I had a California emission equipped 4Runner. Can someone give me the correct aftermarket 02 sensor to purchase? The 4runner is a 2000 v6 automatic trans. Thanks in advance and any advice is appreciated.
From Denso's web site
Find My Part | DENSO Auto Parts
I see that it's 234-9002 if you have the 3.4 engine, 4WD and an automatic transmission.
Same number if it's 2WD.
However, if it has a manual transmission, 234-9003.
By the way, on that vehicle the upstream sensor is, technically, an air fuel ratio sensor, not an O2 sensor.
P1130 code
2000 4Runner, v-6, automatic trans, california emissions
Code reads A/F sensor Circuit range/performance malfunction, bank 1 sensor 1. Do I need to replace the 02 sensor or the mass air flow sensor? Is bank 1 the drivers side?
Mass air flow (MAF) is on the airbox and is different from air/fuel (A/F) which is the upstream exhaust sensor (upstream is Sensor 1). Bank 1 is always the side where Cylinder 1 is which is actually the passenger side on a 4Runner, but, since there is only a single exhaust on third Gens, there is no Bank 2. Bank 1 is all you get for exhaust. Knock sensors, however do have Bank 1 and Bank 2 because there are two cylinder heads.
Replace the upstream exhaust (A/F) sensor. It is not an O2 sensor.
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/024runne/di/eg5vzfe/cip1130.pdf
Thanks Durk. I can save a lot of money if I order a Denso from Amazon. Can someone tell me the correct sensor part number? Thanks
TireSizeDB
